Group: DynoMotion Message: 12138 From: tapiolarikka Date: 8/22/2015
Subject: Mach3 Lathe threading followup
I'm finally so far that I can write feed back regarding the threading bug we discussed a year ago.
During past 4 weeks I have cut close to 6000 threads and have not had a single error relating to the bug that was discovered, so I think it is safe to say that the issue was solved.
Best regards,
Tapio
Group: DynoMotion Message: 12147 From: tapiolarikka Date: 8/25/2015
Subject: Re: Mach3 Lathe threading followup
I do hope that this is my last question to this thread cutting topic:
I  see a short pause in movement after every pull-out move, that I can't get rid off.
Thread cutting pass (G32) and  directly following move (G1 or or G3) work ok with continuous velocity
but then the movement pauses for app 1 sec before continuing with return to pass start.
Normally this would be insignificant, but we cut 15 hours/day @ 47 sec/pc so by end of the week this adds up.
The question is: Is this caused by Mach3 or does it have something to do with plugin or settings?
Rgds,
Tapio
Group: DynoMotion Message: 12164 From: Tom Kerekes Date: 8/26/2015
Hi Tapio,
I can't think of why there would be a delay.   Maybe some Spindle on/off delay?
Can you post your G Code and Mach3 XML Configuration
Group: DynoMotion Message: 12166 From: Tapio Larikka Date: 8/27/2015
I don't mean spindle spinup/down delays, altough I run into them today.
I mean a small delay at the end of each thread pass, similar to delays when mach loads new tool offsets.
I found the problem appears to be on mach side.
Look at reply #9 and #16 by Hood.
I'm also still halfway through investigating if the delays are caused by the macro itself. I can't find where I read it but
somewhere was mentioned that Mach treats macro issued movements ( Code"G1 X100" ) one by on as if they were MDI inputs.
I try to check the effects of the plugin update and buffer ahed times.
I'll post the Gcode and config tomorrow.
Looking at your example video of how kflop makes the threading move made me wonder
- if there were any advantage in converting the G76 to M76 the same way as rigid tapping is performed?
- why the Gcode in the video has two consecutive G32 commands for each pass ?
Rgds,
Tapio
----- Original Message -----
Sent: Thursday, August 27, 2015 1:20 AM
Subject: Re: [DynoMotion] Re: Mach3 Lathe threading followup
Hi Tapio,
Group: DynoMotion Message: 12167 From: Tom Kerekes Date: 8/27/2015
Hi Tapio,
I'm not sure if there would be delay or not in Mach3 after an M Code anyway.
Why not use KMotionCNC?  :}
The two G32's in the Demo are showing how multiple G32's can be blended and remain synchronized in KMotonCNC.  The pull out motion is at 45 degrees and feed rate is increased to maintain the same Thread pitch.  With Mach3 that doesn't seem possible.
Group: DynoMotion Message: 12168 From: Steve Blackmore Date: 8/27/2015
On Fri, 28 Aug 2015 02:05:26 +0000 (UTC), you wrote:
>Hi Tapio,
It is, but why? The pull out is normally done at G0, even when tapered,
as is the return to start position.
There is then usually a small delay as the index is picked up again for
the start of the next pass.
The delay can be noticeable if a very slow spindle speed is used and the
index point has just been passed, program has to wait for next index
point before commencing motion. By slow I mean anything under 500 rpm
I don't see any significant delays as I don't use G1 or G3 for the pull
out and I've cut many hundreds of thousands of threads with Mach.
Steve Blackmore
Group: DynoMotion Message: 12170 From: Moray Cuthill Date: 8/28/2015
I've noticed this problem as well, however I rarely thread on the CNC lathe, so it's not really a problem for me.
One thing I have noticed when I have cut threads, is after the threading move, although the feed mode changes back from feed/rev to feed/minute, the actual figure stays the same until the pull out move is complete, at which point the correct feed/minute rate is applied. I.e. if I'm cutting say a 2mm pitch thread, the mode in Mach changes to 2mm feed/rev for the threading move, then it switches to 2mm/min for the pull out move, before switching back to the previously set G1 speed prior to the return move (I've never actually noticed if the return move is at G0 or G1 speed).
I am planning on moving to KMotionCNC, however I'm currently adopting the "If it isn't broke, don't fix it" methodology, as Mach does what I currently need it to.
Moray
On Fri, Aug 28, 2015 at 3:05 AM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Tapio,
Group: DynoMotion Message: 12178 From: Tapio Larikka Date: 8/29/2015
I uploaded the threading g-code and xml config file along with others here: https://groups.yahoo.com/neo/groups/DynoMotion/files/Tapio/
Delay after M code could be there but that would be 1 delay vs 5 delays when cutting the thread in 5 passes. I cut 16 tpi threads on AISI304 so I don't think I can reduce the number of passes.
Three reasons keep me from moving to KMotionCNC:
- KMotionCNC is the screen layout.  The manual move/jog buttons are (in my opinion) too small, in wrong place and inconviniently grouped for use with touch screen.
  For safety and convenience I feel that jog buttons have to be place so that I can operate them with thumb while grabbing support from enclosure side with other fingers.
  I didn't have time to take a photo of the controller to explain this better but I'll upload it on Monday
  I have keyboard attached only for maintanence and only 3 external buttons for E-Stop, control voltage and cycle start.
- I have a gang tool type lathe setup so I need Y-axis for tool position/slot.
- I use 5C collet chuck that is wedge locked/opened by external hydraulic cylinder and this needs Spindle/A-axis positioning for closing/opening.
  With KMotionCNC I could move the chuck operation to user c code but the two other reasons would still remain.
I tried to modify the KMotionCNC screen with resource editor but came to solution that task and tool don't match.
As soon as I find time I'll try to see if I get the VS2013 community installed to see if it would easier way to modify KMotionCNC.
Rgds,
Tapio
Sent: Friday, August 28, 2015 5:05 AM
Hi Tapio,
Group: DynoMotion Message: 12179 From: Tapio Larikka Date: 8/29/2015
Hi Steve,
I cut the threads at 1000 rpm. I think delay at the beginning is part of the operation but the delay at the end shoud have nothing to do with index.
I looks that G32 threading pass and what ever move comes next are paired as thread and pullout so that they work without delay but the delay after pullout persists.
So far I have tried G0, G1, G3 and G32 as pullout, all with same results.
I also tried G32 thread-G32pullout-G32return to see if the delay would transfer to the end of the return move, but it didn't.
I settled for G3 as machine sounds to run softest this way.
I'm running with Mach43.066 at the moment, but I try rolling back to .062 as soon as I find time.
Rgds,
Tapio
Group: DynoMotion Message: 12180 From: Steve Blackmore Date: 8/29/2015
On Sat, 29 Aug 2015 13:54:57 +0300, you wrote:
>Hi Steve,
I run 3.038
Anything after .042 is bug ridden.
Steve Blackmore
Group: DynoMotion Message: 12183 From: Tom Kerekes Date: 8/30/2015
Hi Tapio,
I tried 3.043.066 and I don't really see the delays (other than the spindle sync)
The G3 arcs seem to be backwards for some reason.
The cycle time for that job is about 32 seconds.
Inline image
Group: DynoMotion Message: 12184 From: Tapio Larikka Date: 8/30/2015
Subject: Re: Mach3 Lathe threading followup [1 Attachment]
I have Mach3 in 3 different PC's and one of them shows G3 backwards ie " )( " while others show "( )"
I get in app32-35 seconds to the M5 command, then some 8 sec to program end.
May well be that this falls in the category "Mach Mysteries".
I think I'll have to work harder toward KMotionCNC, either by vb.net or by VS2013
Big Thank You for bearing with me on this topic :)
Rgds,
Tapio
Sent: Sunday, August 30, 2015 10:14 PM
Subject: Re: [DynoMotion] Re: Mach3 Lathe threading followup [1 Attachment]
Hi Tapio,
The cycl e time for that job is about 32 seconds.
Inline image
Group: DynoMotion Message: 12185 From: Steve Blackmore Date: 8/30/2015
On Mon, 31 Aug 2015 00:14:25 +0300, you wrote:
>Hi Tom,
Think about that - You are in XZ plane on a lathe - not XY ;)
Steve Blackmore
Group: DynoMotion Message: 12186 From: Steve Blackmore Date: 8/30/2015
On Sun, 30 Aug 2015 19:14:03 +0000 (UTC), you wrote:
>Hi Tapio,
You sure? Here's something I wrote in the Mach forum back in 2009 <G>.
Arcs are reversed for a front tool post. Think about it, in the XZ plane
a G2 goes anticlockwise from the operators point of view stood in front
of the lathe. To get the same viewpoint as a mill you'd have lie
underneath it, feet out, looking up :)
Steve Blackmore
Group: DynoMotion Message: 12187 From: Tapio Larikka Date: 8/31/2015
Hi Steve,
The "Arcs are reversed..." sounds familiar. I remember reading it somewhere else also. Now I finally understand the meaning of it :)
Tapio
